Faithbuilders Posted May 27, 2014 Report Share Posted May 27, 2014 I could not respond to original theed. But when I changed over the page.dat, and lang file. The speed dial seemed to work good. but now I can't log in to any of my passport accounts. Link to comment Share on other sites More sharing options...
furkanavshar Posted May 28, 2014 Report Share Posted May 28, 2014 Hi and welcome to forum Faithbuilders, Did you back up the original page.dat file? You can replace it, if you have. I suggest you to update Maxthon from 4.4.0.2 to 4.4.0.4 here http://forum.maxthon.com/forum.php?mod=viewthread&tid=11135&extra=page%3D1%26filter%3Dtypeid%26typeid%3D10%26typeid%3D10 This will change the page.dat file with original one. Please try to delete all files in C:\Users\USERNAME\AppData\Roaming\Maxthon3 Then try to login again. Also it will be better, if you can give more specific details. How can not you login to your passports? Wrong password warning or something? Regards. Link to comment Share on other sites More sharing options...
Faithbuilders Posted May 28, 2014 Author Report Share Posted May 28, 2014 furkanavshar replied at 2014-5-27 18:31 Hi and welcome to forum Faithbuilders, Did you back up the original page.dat file? You can replace ... Thank you for your response; and yes I learned a long time ago, when making changes make sure you back up first. And what it does is, nothing. I click on "switch user account" type in email, and password... and nothing happens. So I replaced the original, back, and it works again, I just don't have the nice speed dial. Link to comment Share on other sites More sharing options...
furkanavshar Posted May 28, 2014 Report Share Posted May 28, 2014 Faithbuilders replied at 2014-5-28 05:51 Thank you for your response; and yes I learned a long time ago, when making changes make sure you ... Ah, I see. I have QA mode and it works fine on 4.4.0.4000 Can you please follow this steps: 1) Disable User Agent and close Maxthon, 2) Delete all files in C:\Users\USERNAME\AppData\Roaming\Maxthon3 2) Update Maxthon to 4.4.0.4000 3) Login 4) Insert QA mode files Then you can change the User Agent again. Let's see if it works (: Link to comment Share on other sites More sharing options...
Tony Posted May 28, 2014 Report Share Posted May 28, 2014 why would a user want to delete all files appdata maxthon3 - i agree it would probably solve the problem but any and all saved data from config to cookies is lost and not all is brought back with a log in to a users passport this is the same sledgehammer method as your common recommendation on a clean install to solve problems poor advice imo Tony - Vivaldi 4 on Windows 10 64Bit Link to comment Share on other sites More sharing options...
furkanavshar Posted May 28, 2014 Report Share Posted May 28, 2014 tony. replied at 2014-5-28 11:34 why would a user want to delete all files appdata maxthon3 - i agree it would probably solve the pro ... He want to use QA mode, but when he changed the page.dat file, Maxthon does not work properly. So what is your advice, Mister? If you don't have a better or different solution, don't talk the hind legs off a donkey, please! Just be useful. Regards. Link to comment Share on other sites More sharing options...
Tony Posted May 28, 2014 Report Share Posted May 28, 2014 useful and are we accepting your advice is useful - changing the page.dat file and the language file will not cause the problems the OP is getting - i do it every build - so we are either not getting all the info or the OP has done something very wrong how in your mind will deleting the maxthon3 dir in adddata cure something in the program files dir that may or may not have been installed incorrectly and what has user agent to do with it so again - useful - you send poor users with problems off to do clean installs that will do little to nothing - you suggest here that a deletion of the config dir will solve this - a better solution you say - well anything is probably better than your suggestion Tony - Vivaldi 4 on Windows 10 64Bit Link to comment Share on other sites More sharing options...
7twenty Posted May 28, 2014 Report Share Posted May 28, 2014 Looks to be a configuration/settings issue. Something might be conflicting with some new settings. Try extracting the portable version somewhere, update the page.dat file and see if the same problem happens. Basically does the same as what furkanavshar said, but you don't have to worry about losing your current data/settings. And means you have a known clean version to test with. Link to comment Share on other sites More sharing options...
