Xeeling Posted December 31, 2014 Report Share Posted December 31, 2014 Google can't work in China, I want to change it to Bing, Thanks Link to comment Share on other sites More sharing options...
15r17e80n12e Posted December 31, 2014 Report Share Posted December 31, 2014 newbie Welcome to the forum!!!:handshake (Alt + F ) Menu --> Setttings --> Maxthon Settings --> Search Engine 11136 11137 Link to comment Share on other sites More sharing options...
~Ohke Posted December 31, 2014 Report Share Posted December 31, 2014 (edited) AND or > For mx Nitro > Press on the adress bar > and you see a dropdown bar (with 9 default options) > Mouse over the Bing icon and > press the ♥ heart icon for Bing. When you come to Bing, make it your homepage or press the link on Bing "Make Bing my homepage"... Now in the Bing page, press on Settings, then WEB, set a mark for [v] Open links in a new browser window. > Save So you can use one page in Nitro for Search and another Tab page for surfing.OBS !! Default search engine cannot be changed yet in Nitro. Maybe in future versions. Best Regards Ohke > Din Hao, dong bu dong ? (^^,) Edited May 22, 2015 by ~Ohke Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted January 1, 2015 Report Share Posted January 1, 2015 Default search engine cannot be changed yet in Nitro. Maybe in future versions. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
Xeeling Posted January 6, 2015 Author Report Share Posted January 6, 2015 15r17e80n12e replied at 2014-12-31 01:48 newbie Welcome to the forum!!! (Alt + F ) Menu --> Setttings --> Maxthon Settings --> Sea ... I ask for Nitro, thank you all the same, I'm old Maxthon user with 3000 hours online Link to comment Share on other sites More sharing options...
Xeeling Posted January 6, 2015 Author Report Share Posted January 6, 2015 Ohke replied at 2014-12-31 12:58 AND ☺ > For mx Nitro > Press on the adress bar > and you see a dropdown bar (with 9 default optio ... This is the way to change homepage but not default search engine, thanks. Link to comment Share on other sites More sharing options...
