dn007_seznam Posted January 1, 2014 Report Share Posted January 1, 2014 Is there any way how to add item to the right click menu from add-in? I do not see any way how to do that. Link to comment Share on other sites More sharing options...
大笨狗 Posted January 1, 2014 Report Share Posted January 1, 2014 You can add menu item in skin file. Modify \main\sidebar\index.htm, then change the Link to comment Share on other sites More sharing options...
SnowLeopard Posted January 2, 2014 Report Share Posted January 2, 2014 大笨狗 replied at 2014-1-1 15:06 You can add menu item in skin file. Modify \main\sidebar\index.htm, then change the element. @dn007_seznam: Theree are skins out that have added functions to the element. So that is possible. But, if you mean can this be done from an add-on, that I do not know. I don't know how an add-on coulld control or modify a skin. Your original post doessn't make clear which situation you actually mean. > Link to comment Share on other sites More sharing options...
