Risen
5.3.8.1300 beta does not work flash player
6 posts in this topic
Flash player stops working after a few seconds with this error. Reinstalling does not help.
Quote
This version of Flash Player is not supported in your region, reinstall Adobe Flash Player.
Hi,
I have same problem (even in the previous version). You can try MX Flash Updater (http://forum.maxthon.com/applications/core/interface/file/attachment.php?id=19846) but it did not work for me.
If you have MX5 and Win10 and 64 bit (similarly it will be for 32 bit versions)
Try: download https://get.adobe.com/cz/flashplayer/ ( Select your Operating System and choose FP for Opera and Chromium - PPAPI) and install it.
Then find in OS  C:\Windows\SysWOW64\Macromed\Flash (64 bit) file pepflashplayer32_XX_X_X_XXX.dll (my actual version is pepflashplayer32_32_0_0_223.dll. and copy this file to C:\Program Files (x86)\Maxthon5\Core\plugins and file pepflashplayer32_XX_X_X_XXX.dll rename to pepflashplayer.dll (restart Maxthon)
Similarly it will be for 32 bit versions. This procedure helped me and flash worked again ;-)
2 people like this
Hi Risen, could you provide the specific URL about this issue?
9 hours ago, ddoe said:
Hi,
I do this and that's work now, thx ddoe.
On 7/24/2019 at 11:30 AM, ddoe said:
Hi,
Thank you, works for me as well, but the target path on my system was C:\Users\USERNAME\AppData\Roaming\Maxthon5\Temp\Flash
