Wisely
MX 5.7.2.2000 and 1000 Drag and Drop cannot work
7 posts in this topic
could you fix drag an drop function?
its' not workable in many web.
for the example: facebook
1 person likes this
Posted (edited)
Works fine for me in both 5.2.7.1000 and 5.2.7.1100; haven't tried 5.2.7.2000 yet. I'm guessing that these are the versions you are referring to as there isn't any 5.7.2.x versions yet. The new core versions are 5.3.8.x.
Edit: Just extracted 5.2.7.2000 portable and 'drag and drop' works as usual for me; used it to get to this thread. Can't speak for the install version; I don't use it anymore.
Edited by rick.lane
Additional information
1 person likes this
Here also works in portable version, both Drag and Drop text and on the links
Hi Wisely,
I tried to test this issue with Windows XP and 10 but cannot reproduce it.
You could try to disable the unofficial extensions or restore the browser settings to default.
7 hours ago, BugSir006 said:
Hi Wisely,
Hi
I am try at before. restore to default or remove all extensions.
it's not workable
I can see drag drop, but it's not open in new page or search by google.
did you check to see if it is enabled in settings?
if so, disable/enable and try again.
It hasn't worked properly on Facebook for a very long time, due to their own JavaScript mangling the functionality.
In v5.3.8.500, drag-and-drop on a link does correctly open a new background tap with the URL location in, but also opens the URL in the active tab. If I press Esc before the load has been completed however, it then doesn't do it for any further drag-and-drops on the present page load. Windows 10 x64.
