goro2934742
Problem PassKeeper
6 posts in this topic
For several months, the problem has not been solved. What to do? From the smartphone in this section, you can go.
Hello,
If this issue happens again please launch the Fiddler to check the result of the URLs in the screenshot.
FiddlerSetup.exe
4 minutes ago, goro2934742 said:
write detailed instructions how to do it
If this issue happens again please launch the Fiddler, then try to enter the Passkeeper again, you will see the "result" and "URL" in the fiddler page.
Check the result of the URLs and let us know your phone number. You can check the URLs which we need in the last screenshot.
The dev team can analyze and judge the issue according to the URLs' result.
39 minutes ago, goro2934742 said:
Where to send? Are you in private messages?
Yes, you can. :wink:
