Daryl Dixon
Facing Problem while accessing Wikipedia?
4 posts in this topic
I notice that if I try to access Wikipedia at the default settings in Maxthon I get the following message "Error code 100 (net::ERR_CONNECTION_CLOSED)" and the page does not open. The workaround solution that I found is to use the switch core setting to IE (the default works). inro.in/watch-movies-online/ inro.in/cyberghost/  inro.in/expressvpn/ Is this a known issue with the particular website????
1 person likes this
No problem here with Wikipedia using default settings.
4 hours ago, Daryl Dixon said:
I notice that if I try to access Wikipedia at the default settings in Maxthon I get the following message "Error code 100 (net::ERR_CONNECTION_CLOSED)" and the page does not open. The workaround solution that I found is to use the switch core setting to IE (the default works). Is this a known issue with the particular website????
no problem either
did you change the user agent string ? if yes,  set it back to defaultuser.jpg
