Jus5631410
confirmed Status bar display indicator information problem
10 posts in this topic
Hello!
I noticed that Status bar display indicator information has some problems on "no user account" MX 5.2.6.1000. When I set information (see attached image Info_1.png below) through the "Customize UI" buttom, next time or some days later some information just disappeared from the status bar only "System info" remained. If I click on Menu all the Information are unchecked (see attached image Info_2.png below). Same also when I check information from the "Menu" I have the same problem. In the "account user", I don't have such problem.
Thank in advance for your help.
Jus
Hi Jus,
Thank you for your feedback. Did you use the administrator account or guest account of this device?
7 minutes ago, BugSir006 said:
Hi Jus,
I reported exactly the same issue a while ago..  still not fixed
I use an administrator account
Hello ody,
I tried to test this issue with the administrator and the guest account but I cannot reproduce. I will continue following it. :)
Thank you for your reply. When I said "user account" or "guest account" and "register account", I am referring to MX accounts not the computer accounts. I am sorry if this created some confusion.
Thank you.
Jus
This problem occurs regularly. Just close down Maxthon and then reopen it.
3 hours ago, BugSir006 said:
Reproduced! :5884970a7da3a_1:
at last !!!!
1 person likes this
Thanks to all of your replies. i hope the developers will do something.
Jus
1 person likes this
