TarMaster
MX5 PC Beta release 5.2.6.1000 Dowload Manager Clear History problem
13 posts in this topic
I use MX5 PC Beta release 5.2.6.1000 portable version. This is very good version....
But Download Manager option: "Clear History" is not working properly.
"Celar Invalid" - NOTHING CLEAR, not working. It did not work in the earlier version.
(Or only for me?) Other Clear options working well!
Maybe it should be improved in the newer version.
Cannot confirm or reproduce, also using 5.2.6.1000 portable. Sorry.
I do not confirm either. It works well, it deletes both the history and the downloaded files (if I wish) . Portable version too
Likewise. I do not confirm.  However I wonder if you meat the download dialog (where you select the download path) instead of the download manager itself?
That I haven't tested at this time.
                                        <<SL>>
Posted (edited)
I'll tell you with images my problem.
I delete all history and clear data in browswer. But same poblem.
I select the download manager. "Download" (See first image.)
Then i see one invalid (deleted) file (WinUtilitiesPro.rar). (In hungarian: "Nem található")
Then I click "Clear invalid", but the invalid file remain in list.
"Clear all" and "Clear all histories and files" button working fine - except "Clear invalid" button.
Edited by TarMaster
3 minutes ago, TarMaster said:
I delete all hystori and clear data in browswer. But same poblem. See mx5_error_01, and mx5_error_02 images.
OK my test did not reveal the drop-down menu; I judy clicked "Clear History" and everything was gone.  But "Clear Invalid" wouldn't work because I didn't have any invalid entries.
                                              <<SL>>
1 person likes this
                                              <<SL>>
Clearly that's not a solution. It is better to resolve the actual issue rather than giving alternatives.
Agreed!!  I never thought it a solution;it's just a description of my test.
                                           <<SL>>
ok, now better explained / understood :-)
I confirm, it does not work as you explain.
On the other hand, of these two ways, if you delete this invalid download
OK. This second method work for me to. But "Clear history" is more elegant and faster :)
if you have already started to upgrade the download manager, then make the really necessary function - this is the adjustment of the speed of loading and unloading
Hello,
Thank you all for your feedback. This issue has been reported to the dev team. :Smiling_Face_Emoji_with_Blushed_Cheeks_42x42:
1 person likes this
12 hours ago, BugSir006 said:
Hello,
Hello! Thank You! :Smiling_Face_Emoji_with_Blushed_Cheeks_42x42:
