· #1 Posted 1 Nov 2018 Since as far as I remember Mx 5.2.1.xxx I cannot print anything in Ultra mode. Print dialog just hangs. It is possible to go back in a very few seconds, after that the tab completely hangs. Share this post Link to post Share on other sites
· #2 Posted 1 Nov 2018 No problem with official portable version 5.2.4.3000 Neither with portable version 5.2.5.2000 official, in clean installation 1 person likes this Share this post Link to post Share on other sites
· #3 Posted 1 Nov 2018 47 minutes ago, pantantrollo said: No problem with official portable version 5.2.4.3000 Neither with portable version 5.2.5.2000 official, in clean installation Good for you. I work on 3PCs (1 notebook, 2 desktops, all on W10). Everywhere situation is the same. Share this post Link to post Share on other sites
· #4 Posted 1 Nov 2018 30 minutes ago, observer said: Good for you. I work on 3PCs (1 notebook, 2 desktops, all on W10). Everywhere situation is the same. I also work on windows 10 x64 Have you tried a clean installation? , the easiest way to download a portable version Share this post Link to post Share on other sites
· #5 Posted 1 Nov 2018 5.2.5.2000 portable didn't help Share this post Link to post Share on other sites
· #6 Posted 1 Nov 2018 using passport or guest account? if using passport, test with guest and see if it still happens. Share this post Link to post Share on other sites
· #7 Posted 2 Nov 2018 8 hours ago, 7twenty said: if using passport, test with guest and see if it still happens. It doesn't matter. Both of them give the same result. Share this post Link to post Share on other sites
· #8 Posted 2 Nov 2018 2 hours ago, observer said: It doesn't matter. Both of them give the same result. Hi observer, Do you use the intranet? Share this post Link to post Share on other sites
· #9 Posted 2 Nov 2018 3 hours ago, BugSir006 said: Do you use the intranet? mmm.. I'm not sure I understand you well. Yes we have a company network in the office. But at home my devices connected via router. Share this post Link to post Share on other sites
· #10 Posted 2 Nov 2018 41 minutes ago, observer said: mmm.. I'm not sure I understand you well. Yes we have a company network in the office. But at home my devices connected via router. Have you checked "allow all sites to run plug-ins"? Share this post Link to post Share on other sites
· #12 Posted 5 Nov 2018 On 11/2/2018 at 8:31 PM, observer said: Sure. Reproduced, I have reported this issue to the dev team as a bug. 1 person likes this Share this post Link to post Share on other sites
· #13 Posted 13 Nov 2018 On 11/1/2018 at 8:57 PM, observer said: Since as far as I remember Mx 5.2.1.xxx I cannot print anything in Ultra mode. Print dialog just hangs. It is possible to go back in a very few seconds, after that the tab completely hangs. Hi observer, Can you reproduce this issue in the latest beta? Share this post Link to post Share on other sites
· #14 Posted 13 Nov 2018 I'm afraid, I see no changes in 5.2.6.500. I made a clean install. Share this post Link to post Share on other sites
· #15 Posted 13 Nov 2018 45 minutes ago, observer said: I'm afraid, I see no changes in 5.2.6.500. I made a clean install. I am on the same version and I have not problem printing in Ultra mode. Printed yesterday and today without a problem. Windows 10 insider preview 18277.1006 1 person likes this Share this post Link to post Share on other sites
· #16 Posted 14 Nov 2018 what happens when you click "change" or "print using system dialog"? 1 person likes this Share this post Link to post Share on other sites
· #17 Posted 9 Dec 2018 In the latest release (5.2.6.1000) this issue was fixed. Thank you all. 2 people like this Share this post Link to post Share on other sites
· #18 Posted 20 Dec 2018 Just FYI. The issue arose in Mx 5.2.7.100-beta again. 1 person likes this Share this post Link to post Share on other sites
· #19 Posted 21 Dec 2018 9 hours ago, observer said: Just FYI. The issue arose in Mx 5.2.7.100-beta again. Hi observer, Please try this issue with browser guest account. 1 person likes this Share this post Link to post Share on other sites
· #20 Posted 21 Dec 2018 (edited) The behavior is the same. No matter, authorized or guest account is used. Edited 21 Dec 2018 by observer Share this post Link to post Share on other sites
· #21 Posted 22 Dec 2018 bug have fixed before if i remember correctly. Share this post Link to post Share on other sites
· #22 Posted 24 Dec 2018 On 12/21/2018 at 1:13 AM, observer said: The behavior is the same. No matter, authorized or guest account is used. Cannot reproduce... I recommend you to disable the external extensions. Share this post Link to post Share on other sites
· #23 Posted 25 Dec 2018 On 12/22/2018 at 8:34 AM, 7x3twenty1 said: bug have fixed before if i remember correctly. Yes, you are right. Imho, devs took not latest code to 5.2.7.100. On 12/24/2018 at 5:49 AM, BugSir006 said: Cannot reproduce... But, BugSir006 says, he is ok with this. So, it's my local problem again. On 12/24/2018 at 5:49 AM, BugSir006 said: I recommend you to disable the external extensions. I have only 2 additional extensions: Site search and No mouse restrict. 1 person likes this Share this post Link to post Share on other sites
· #24 Posted 25 Dec 2018 (edited) I have the same problem as @observer Options Cancel, Change or "Print using system dialog" not react to clicking. Edited 25 Dec 2018 by Galileusz 1 person likes this Share this post Link to post Share on other sites
· #25 Posted 26 Dec 2018 16 hours ago, Galileusz said: I have the same problem as @observer Can we have a remote via TeamViewer? 1 person likes this Share this post Link to post Share on other sites
· #26 Posted 26 Dec 2018 6 hours ago, BugSir006 said: Can we have a remote via TeamViewer? Rather not, I value my privacy and I do not allow remote access to my PC from outside of my network. I also use another, fully customizable browser (SlimJet), so I can use from this function. I use Maxthon a little from habit and a bit of sentiment 1 person likes this Share this post Link to post Share on other sites
