einherz
Small fonts on some pages
19 posts in this topic
some sites open with incredible small font,example - gmail (win10)
Cannot confirm.  Fonts are fine on Gmail for me.
had the same happen.
it's due to the new font sizing feature they added.
Go to settings > Advanced, Web page display. For page font size, select Medium (even if it is already), and it should fix itself. Reset to default should fix it as well.
Must be some sites reading the setting differently initially or something.
Posted (edited)
must be your browser no prezoom gmail page, i think this could be, because my gmail open with some prezoom(ctrl+), in any way i back to 5.2.4.700, and all sites work as usual
7twenty
thank you, did not catch your post first time, sorry
and yes, it's working for me, now everything ok, btw, i use portable version
ah, now when browser start i see this
p.s. oh, now relogined, and no problema lol
Edited by einherz
Then why aren't more people having a problem with fonts?  I have always used the installed version, could it be the portable that is the problem?
i don't know,  I just added 1+1 when i found the problem. Turned out it fixed it.
Also why i added "or something" in the last sentence.
Perhaps you missed the update in settings adding font size oreference in MainMenu>settings>Advanced>Fonts.  It is in the Change Log.  I did recall that when I ran into extremely tiny fonts on ABC.com.  Clicking "Reset to Default" clears the problem and it has been permanent since then.
                                    <<SL>>
                                    <<SL>>
Ok, if I have never had a problem with fonts of any kind, why would I go looking for a setting to change something and create a problem?  As the old saying goes, "if it ain't broke, don't fix it"
1 person likes this
BUT - [add sarcasm smilie] thats how they seem to work - add something that nobody wants whilst old bugs go on and on and requests that have been around for yeas are ignored
1 person likes this
You wouldn't, nor was it ever implied that you should if you didn't have the problem.
Seems you're the only one making more of this than what there is. There was a problem, a new setting change seems to be related to it, reset it and it's all back to normal.
While there's some truth to that, i don't think we need to turn this thread into another "they don't listen to us" thread.
When you trying search something on google and duckduckgo search pages are zoomed out and looks like this
Google
Duckduckgo
see post #3
Im using Maxthon 5.2.4.1200 portable. Why am I getting smaller fonts ? I tried this in different computers with the same results. This is happening since the previous version.
There was a new option added in MainMenu>Settings>Advanced>Web Page Display called Page Font Size.  The default is "Medium but theree's a problem with recognition of this setting initially, so pages display ultra-tiny (fonts and images).
You can correct it by changing "Medium" from that to another setting and back to Medium.  Easier is to click "Set to Default" button.  I think this is good for a Mx5 session, but may  need repeating each time you launch until a fix is made - inconvenient to be sure.
                               <<SL>>
Can't read any content more after updating to 5.2.5.4000
the fonts are to small
Posted (edited)
Quote
 · #3
Edited by Magdalene
