DaveMax
resolved Mx 5.1.4.3000 Issue
8 posts in this topic
Every time I open a page from the bookmarks bar or the speed dial I get this downloader pop-up.
It's driving me mad, how do I stop it?
Settings > Advanced > Uncheck Show video floatbar
What if he wants to popup a video? He has a problem I don't have despite using the popup button.
He asked for a fix, I gave it to him.
He'll need to determine what's more annoying - either no popup, or deal with the floatbar in that scenario.
I'm guessing it doesn't happen on all sites, just that he might go to a lot that use HTML5/Flash content so it seems that it happens a lot.
It's happening on every site. I guess if I want a pop-up video I'll have to enable pop-ups for that page. Thanks for the fix though, it will suffice for a bit I suppose.
Well that ain't right. I know you said every site, but can you provide one so i can have a look and confirm that it's the site not something else.
Only other reason I can think of that would cause that, is an extension that is adding some code that the floatbar is picking up and showing. Otherwise there's no reason why it should show all the time.
If you're running any extensions, try disabling them all and see if it still happens.
I have hundreds of bookmarked sites, it pops up on every one of them that I have tried. I have no extensions. I've tried a fresh install. I'm running Win 7 x64.
