Desberx
pc issue Maxthon 5.1.3.1000 error problem
12 posts in this topic
I have this error since I updated to version 5.1.3.1000, every time I go to Rockfile, with the previous one not happening:An extension caused this webpage to stop working. Please disable any extensions that may block ads to continue.ERROR_19847. How do I fix it?I would replace the previous version, but I do not know what it was ...
40 minutes ago, Desberx said:
Rockfile
Link to site please... can't figure out what that is.
Here is the site:http://rockfile.eu/4ske8bpk5fc8.html
Buenas,
No problem here, with v5.1.3.1000 (official)
check the extensions you have installed and disable those that are not specific to maxthon
Un Saludo
1 person likes this
Wait, I did not explain well. The problem occurs when I get to the download page, and I wait for the wait time to start downoad, then this error appears.
Disable Adblock Plus for the site. Seems to have some good adblocker detection.
From the ABP button in the toolbar, uncheck the "block ads on this website" option.
Hello! I on 5.1.3.1000
1. Go to site - ok.
2. He says: Disable ABP
3. I disable ABP.
4. select free download.
5. write capcha.
6. prepairing link...
7. start download.
Work's fine. But without ABP.
It seems that even with violent monkey scripts this site detects adblock
i've tried with comodo dragon, with some violent monkey scripts and additional extensions; through a VPN
and i get rid of those adp disable warnings
same good result with opera developper extensions and VPN
Do you know what version is previous to 5.1.3.1000? I would like to put that ...
