TheWhitestOfFangs
resolved Problem with specific website (http://ignition.customsforge.com/)
7 posts in this topic
Hey,
There's an issue with the following site:
As can be seen, the content is "squeezed" at the top and, although clickable, not really helpful. I have tried with the Ad-block turned off as well, just to be sure - with the exception of ads, doesn't change anything.
Maxthon Version 5.1.0.4000
Win7 x64
39 minutes ago, No.1MaxthonFan said:
Works fine in 5.1.1.100
confirm
So I've updated to beta 5.1.1.300 and still no go...
I'll point out that I login with a user/pass and you maybe not - which might be the difference.
http://ignition.customsforge.com/ - stuck at "Redirect..."
This also happens in other sites, such as:
https://software.intel.com/en-us/blogs/2009/03/31/doctor-fortran-in-ive-come-here-for-an-argument
In both cases, the text/content appears for a second - and "vanishes".
Not sure why it is hidden - it is not ad-blocked (I check with AB turned off)
While you might be right about logging into the other site, the intel page works for me.
Have you tried working through the troubleshooting list? http://forum.maxthon.com/index.php?/topic/21475-maxthon-troubleshooting-tips-and-tricks
You say you already tried disabling ABP, but you've also got a number of extensions running. Start disabling them and work from there.
Both pages loaded fine but I didn't use or create an account for either.
Ok, apparently it was one of the extensions that I did not notice (When thinking that I've turned them all off).
