Mario.NET Posted June 10, 2017 Report Share Posted June 10, 2017 This is Mathon 5.0.4.3000 doing nothing, On Maxthon 4, the used CPU was about 0.4% I suspect the cause to be the new Quick Access. If that's right, please include an option to return to the old version, thanks Also, clicking on the little X on a QA icon should ask user for confirmation, before deleting it Link to comment Share on other sites More sharing options...
karajan Posted June 12, 2017 Report Share Posted June 12, 2017 they are many threads about that, multiple process is part of new browsers, nothing to deal with. so there is a difference between MX5 and 4; you always can use a guest account on mx5. finally stay with MX4 if CPU usage is a killer point clicking on the x or delete menu gives no warning ( supposing you do it for fun that is not a good thing ): so on the other browsers it's the same unless there is a recycle bin Link to comment Share on other sites More sharing options...
Mario.NET Posted June 12, 2017 Author Report Share Posted June 12, 2017 But I am not bothered by the many processes The problem here is the CPU is running (and the battery draining, and the fan spinning louder, ...) for absolutely no reason, as Maxthon is only open, without any page loaded in it And am I the only one, that sometimes click some pixel to the right to where I want to (and deleting an icon withount any warning) ? Link to comment Share on other sites More sharing options...
Golfmann Posted June 12, 2017 Report Share Posted June 12, 2017 Memory leaking is horrendous! and major programming sin is not releasing memory on closing! Shame! Link to comment Share on other sites More sharing options...
BugSir006 Posted June 13, 2017 Report Share Posted June 13, 2017 On 6/10/2017 at 6:26 AM, Mario.NET said: How can I also get this pic? Is that from windows task manager? Link to comment Share on other sites More sharing options...
Mario.NET Posted June 13, 2017 Author Report Share Posted June 13, 2017 Yes, windows 10 task manager Click on 'More info' in the lower left corner Link to comment Share on other sites More sharing options...
