David Košecký
Problem with userscript on ViolentMonkey plugin.
12 posts in this topic
Posted (edited)
I want to install "Clear dark facebook by book777" userscript using Violent Monkey plugin, but it doesn't work on latest MX5 (tested on Google's Chrome)
Tried solution:
1) Adding @grant from this page.
2) Disabling all extensions.
3) Other themes works.
Solution:
NOT SOLVED: waiting
I also speak with the author of this theme, but he couldn't find solution yet. Theme's working for other browsers judging by comments on userstyles.org.
Does anyone know why isn't it working on latest MX5? :(
- David Košecký
Edited by David Košecký
14 hours ago, PHYR said:
You can find other scripts for FB here: https://greasyfork.org/en/scripts?q=facebook.com
But I use this one which works on all (mostly) sites https://greasyfork.org/en/scripts/15675-nightvision-mode-夜间模式
Here's how FB looks with it.
Thanks for tip, but i don't like this theme.. :/
I want to fix that "clear dark facebook by book777"
Been playing around to see where the issue is. Only thing i've found so far is that it's having issues with some of the variables set for colours, it won't read them so nothing happens.
1 person likes this
where can I find this script and have it installed?
Oh, finally I figure out what are you talking about.
I tried to install "clear dark Facebook" using the Stylish extension, while the "install" process never starts after clicking.
So I then tried "install style as userscript", the install succeed, while no change for the facebook theme. And it popped up the warning saying @grant issue.
I'm wondering how can Maxthon help in this case with the info provided that the author had so solution either?
Problem shouldn't be in @grant. I spoke with the author of this theme and he said that MX5 didn't support  :root (css).
Is it really it? Perhaps add support for it?
1 person likes this
I'll check this with our developer. So  :root (css). is a kind of HTML format selector?
But I doubt that Maxthon will change at this point just to support one theme from an extension. So if there is any alternative to the extension or the theme, I hight suggest you change the extension.
No need for alternative... Problem isn't in ViolentMonkey plugin, but in MX5.
Here is proof: https://jsfiddle.net/e9me6kud/
As far as i know :root CSS should be way to make CSS (judging by informations from theme maker).
