Jus5631410
confirmed Button problem in MX5 Android release 5.0.5.303
5 posts in this topic
Hello!
I want to thank the developers for their work. I think the new version MX5 Android release 5.0.5.3035 is better. I am happy to work with this version. The only problem I noticed is that one button when I tried to exit the program is showing an exit window with something like "@android:string/annuler" at the left and "Confimer" at the right. I think the left button has a display problem. Instead of displaying only "Annuler" which means "Cancel" in English, the program is adding something else. The right display will be "Annuler" at the left and "Confimer" at the left. I do not know if the English version has this problem but French version does.
Thank you advance for your reply.
Jus
Hey there, thanks for the reporting. Could you tell me which language do you use on your mobile?
If you could provide a screenshot of this, it would be great!
Please let us know your language so we can have a check on the strings. :)
Thank you for reply.
I use "French language" as default on my tablet 10" Acer A210. See the joint file for more details. I hope the image will be fine.
Thank once more.
Jus
1 person likes this
Hi Jus, really thank you and the photo is quick helpful. We've identified the problem is in the French language file. Our language staff has updated the string and will forward the revised file to our Android product manager. So this issue should be nowhere to be found in next version. Thanks for your reporting again!
With pleasure.
Thanks to the developers for their effort. Let us work together to make Maxthon a better browser.
Jus
