phoenix-76
resolved MX 5.0.2.2000 fullscreen problem
18 posts in this topic
Issue description:
A white 1px wide border/frame is displayed around the MX5 browser content when F11 full-screen is activated from smaller than fully maximised MX window.
How to duplicate:
Run the MX5 browser in a windowed mode (window size must be smaller than maximised), open any web content with dark background and press F11. The issue is very apparent and annoying while watching fullscreen youtube videos -> play any youtube video in a windowed MX5 and activate the fullscreen within the YT player.
Test scenario:
The issue seems to be independent of any particular OS/HW configuration. I have duplicated it on Windows 10 Home 64-bit multi-monitor setup with discrete nVidia video card with the latest drivers at 2560x1440, 1920x1080 and 1600x1200 resolutions as well as on Windows 7 Pro 32-bit laptop with embedded Intel graphic at 1920x1080 resolution.
Please respond.
1 person likes this
Hi there, could you tell us what the exact issue is?
Here's a short video I made w/t 5.0.2.2000 on win7
Thanks, BugSir006. PHYR and I are apparently getting different results than you do. Attached is a picture of the screen I'm getting following the exact steps you took in your video. As said before - very apparent and VERY annonying.
I'm on win10 b15031
The problem is the white border surrounding the video in fullscreen mode, it should not be there.
I've just run another test which may indicate there's something wrong with MX5 screen size detection.
1. Start MX5 in a windowed mode.
2. Press F11 to invoke full-screen mode.
3. Press Alt+F4 to close the MX5 app.
4. Check content of c:\Users\_user_name_\AppData\Roaming\Maxthon5\Public\LastData\lastdata.ini
5. Compare the window_pos parameters with your physical screen resolution.
I ran the test on a regular full HD 1920x1080 screen, despite that the lastdata.ini file content looks like this:
   [window_pos]
   left=0
   top=0
   right=1916 ... should be 1920
   bottom=1076 ... should be 1080
   max=false
   [last_skin]
   is_def=1
Can somebody else please try to duplicate and confirm this issue to have it officially acknowledged as a bug and to prevent this thread from fading away?
I managed to consistently duplicate the problem with white border surrounding fullscreen videos on three machines already, one of which was a completely fresh install. The resolutions tested so far were 2560x1440, 1920x1080, 1200x1600 (portrait mode).
I also noticed that the test run by BugSir006 was probably performed in some lower screen resolution, so it might be advisable to preferably verify the problem on full HD and higher resolutions.
Hi there, thx for the follow-up. Although I cannot reproduce it on my device, I'll forward the detailed info you provided above to our professional testers. Hope they can reproduce it after testing on various devices.
ah! I reproduced it!
and I found that the point is "windowed mode"!
Edit: 2017-03-08
this issue has been confirmed as a bug, and our programmer are working on it.
1 person likes this
I've had this bug since the alpha build. Video won't go into fullscreen mode, rather it will go into a windowed mode.
please resolve the new TABs opening issue to the right when we want multiple screens opened it is not working, please look at Mozilla Firefox how when
you open the new tabs how they open seperately, rectify the bugs please
Hi guys...
Bug, i already reported this kind of problem a few versions back, when we were still on version 4... Never was it fixed...
If maxthon is opened in window mode it will not maximize video correctly most of the times letting the taskbar on top of the video and not overlapping everything. If maxthon is already maximized it will go fullscreen correctly.
Made a quick video showing the problem.
Oh, btw, is there a way to change the floating video bar position on the fullscreen videos to somewhere diferent than the lower right corner? Most of the times it blocks the fullscreen/mute buttons.
Fullscreen_video.webm
1 person likes this
could you provide a specific video link? or it happens on all videos on all site? Are you using the latest version 5.0.2.2000? It happens when you click the "fullscreen" button on the video or when you click the full screen mode on browser?
Do you mean that you want each tab open in a new window like IE?
1 person likes this
@BugSir006
Installed a few mins ago latest version 5.0.3.900 and fullscreen problem is still not fixed...
youtube videos and other from facebook don't go full screen if axthon browser is in window mode. If the window is maximized it will go fullscreen without problems as before.
Hey Danny, we've confirmed this bug and it's in the queeu now.
It ranks as 4 in our bug priority system. 1st rank it the top priority.
Since this bug will not affect the main user experience and you can have it right when get it full windowed first, so we gave it a 4.
But this doesn't mean that we'll not fix it, we will do it later and deal with the serious ones first.
Thanks for your follow up and hope you can understand. :Smiling_Face_Emoji_with_Blushed_Cheeks_42x42:
1 person likes this
Hello, can someone please advise why this issue is marked as resolved when it obviously still persists with 5.0.3.2000?
1 person likes this
Hello BugSir006, five MX5 releases later the fullscreen issue still persists with 5.0.3.3000.
Could you please update us on the progress and fix ETA? My initial understanding was that priority 4 meant the issue would be looked at right after three more urgent problems. I however see that almost 40 different bugs were fixed according to the official change logs since the fullscreen problem was reported. I'm therefore inclined to believe you meant you had assigned the problem with level 4 priority (e.g., 1=Critical, 2=High, 3=Medium, 4=Low) because several people on this forum know how to work around this annoyance. Any chance the priority could be elevated and the bug fixed in some of the upcoming releases?
I confirm this issue fixed in 5.0.4.500. Thank you! :)
1 person likes this
Cool! Happy to help!
