Yuizen Posted January 3, 2017 Report Share Posted January 3, 2017 I can't seem to understand why when I install MX5 all my auto-fill and saved passwords in MX4 is not there. Anyway to import them from MX4 to MX5? Link to comment Share on other sites More sharing options...
7twenty Posted January 3, 2017 Report Share Posted January 3, 2017 Are you signing in with a passport account? If so, it should have all automatically been imported. Is other data like favourites imported correctly? If neither is there, and you didn't get a notice to import your data - goto Menu > Tools > Import/Export Userdata > Import user data > Choose one of the import from MX4 options Link to comment Share on other sites More sharing options...
BugSir006 Posted January 4, 2017 Report Share Posted January 4, 2017 Hi Yuizen, Please try 7twenty's suggestion and see if your problem can be solved. Please feel free to tell us any feedback! ;) Link to comment Share on other sites More sharing options...
Yuizen Posted January 5, 2017 Author Report Share Posted January 5, 2017 On 1/3/2017 at 2:45 AM, 7twenty said: Are you signing in with a passport account? If so, it should have all automatically been imported. Is other data like favourites imported correctly? If neither is there, and you didn't get a notice to import your data - goto Menu > Tools > Import/Export Userdata > Import user data > Choose one of the import from MX4 options Thanks for pointing out the import thing. I'm trying it now. It solved the problem. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
