pantantrollo
WinPC Confirmed Problem Exporting Favorites in v.5.0.2.1000 / 900 / 2000
13 posts in this topic
Hello,
When a group of URLs with date / time format has been saved, it occurs when exporting:
In Urls groups with time format "-", folder export and Urls are done correctly
In Url groups with time format ":", the export creates the folder, but the Urls export is not done, leaving the export folder empty
Un Saludo (I'm sorry for my English)
Hola pantantrollo,
May I know how do you get this window?
Since after I choosing export/import favorite, then I get this, and then I can proceed to export all my favorite to a html file.
But I found that the language file for espanol has a small problem, it still shows in English.
2 hours ago, BugSir006 said:
Hola pantantrollo,
He had in mind "Add all pages to Maxnote"
Thanks for the explanation!
11 hours ago, BugSir006 said:
Hola pantantrollo,
Yes, this happens when exporting to folders, not to html file.
I think it's because windows does not accept ":" as a character in directories and then export fails in those folders.
Un Saludo
Hi pantantrollo,
Thanks for follow up.
But still, whether I chose to export to a folder or to html file, I didn;t get this window.
Here is what I did and what I get, can I also have a short video from you so that I know how I can get the pop-up window as you?
On 4/1/2017 at 3:57 AM, BugSir006 said:
Hi pantantrollo,
Hi, BugSir006
This video is correct, But the problem is not with that, it is with the export itself
Do the following:
- Add a group of tabs, (Figura_1)
- leave the name that shows you by default (with the included time) (Figura_2)
- export to favorites, and check if those URLs have been saved to disk (like in you video)
Do you see the added URLs in the exported folder? (Figura_3)
Un Saludo
Confirmed here as well.
I also confirm. There is a problem with the colon ":" in date.
Exporting favorites no fIx in this release 5.0.2.2000 :-(
Un Saludo.
Hi pantantrollo, thanks for the follow up and sorry that this issue is not fixed in this version.
The steps you provided above are quite clear and useful! Will soon tell our testers try as you described.
BTW, I also reproduced it.
Hi there, the problem you reported here has been confirmed as a bug by our testers and will be fixed by our developers soon!
Very thx , BugSir006 !!
