Using Flash Player Online Settings Manager.
MX5 Chromium based browsers – PPAPI
We use Chromium based browser, them to change the Flash Player settings, use the Flash Player Online Settings Manager.
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html
Warning:
The Settings Manager that you see onto link above is not an image; it is the actual Settings Manager.
Click the tabs to see different panels, and click the options in the panels to change your Adobe Flash Player settings.
Use this panel to reset the privacy settings in Flash Player:
Note:
That if you have installed the PPAPI version of Flash Player, you must use the Flash Player Native Control Panel to configure your update settings.
If you are using Chrome, you will get the updated versions of Flash Player through the Google Chrome update mechanism.
