PhotoGyulai Posted May 16, 2016 Report Share Posted May 16, 2016 Hey! I just installed maxthon to my new system (win 7) and smething wrong with flash player... ( not work at all) I did everything what this topic says: double checked, restarted maxthon and the system.... but no change... any else idea?!? (why it is so hard to set something so usual?!?!) Link to comment Share on other sites More sharing options...
-ody- Posted May 16, 2016 Report Share Posted May 16, 2016 39 minutes ago, PhotoGyulai said: Hey! I just installed maxthon to my new system (win 7) and smething wrong with flash player... ( not work at all) I did everything what this topic says: double checked, restarted maxthon and the system.... but no change... any else idea?!? (why it is so hard to set something so usual?!?!) please check if you have enabled plug-ins in maxthon settings Link to comment Share on other sites More sharing options...
7twenty Posted May 16, 2016 Report Share Posted May 16, 2016 4 hours ago, PhotoGyulai said: I did everything what this topic says: I can only suggest you did something wrong, as that method has been checked numerous times and I have never had an issue with it working. You can try the auto-updater by truuuc and see if that works for you. Link to comment Share on other sites More sharing options...
BugMiss006 Posted May 17, 2016 Report Share Posted May 17, 2016 what kind of situation of "flash player can't work" you got? can't play video or...? Link to comment Share on other sites More sharing options...
PhotoGyulai Posted May 22, 2016 Author Report Share Posted May 22, 2016 On 2016. 05. 16. at 9:02 PM, -ody- said: please check if you have enabled plug-ins in maxthon settings thanks that was it!! may i suggest the owner of the " Adobe Flash and Maxthon " topic to update the description with this check!! note: yes the videos was not played... and yes im 4.9 version! thanks 4 help! Link to comment Share on other sites More sharing options...
-ody- Posted May 22, 2016 Report Share Posted May 22, 2016 1 hour ago, PhotoGyulai said: thanks that was it!! you're welcome ! Link to comment Share on other sites More sharing options...
14072353 Posted May 24, 2016 Report Share Posted May 24, 2016 I have enabled plug-ins in maxthon settings and my flash still will NOT work. Now what? Thanks! Link to comment Share on other sites More sharing options...
-ody- Posted May 24, 2016 Report Share Posted May 24, 2016 2 hours ago, 14072353 said: I have enabled plug-ins in maxthon settings and my flash still will NOT work. Now what? Thanks! try this please Link to comment Share on other sites More sharing options...
