Magdalene
Problems downloading Flash 19 beta
4 posts in this topic
Maxthon (I've tried various versions) can no longer download Flash 19 beta from this site  http://labs.adobe.com/downloads/flashplayer.html. Still works on Chrome.
Can anyone confirm?
No problem here.
Did you try clean your Temp, cookies and so one..?
Check also Adblock/ your filters.
post-4817-0-00497000-1439746445_thumb.jp
Using Win 8.1. The flash beta's used to download fine until the last version and that coincided with the arrival of Mx 4.4.7.1000. I've tried other versions of maxthon after cleaning cookies etc on the same download and none of them will download. Will try with Adblock disabled.
Have tried with Adblock disabled and it still doesnt work.
Downloads fine on Mx 4.4.1.5000 Portable.
Clean Install fixed the problem on MX 4.4.7.1000.
