Sign in to follow this
Followers 0
Weng Loong Tai
Having static sound when using Maxthon
9 posts in this topic
When I use Maxthon browser, there is static sound come out randomly from my speaker.
I tred use headset, same thing happening.
It's fine when i use Chrome.
weird, never heard such a sound either...
Never had an issue like that.
Check to see if one of the tabs open is causing it. What happens when you click the mute button on the status bar? Does the sound stop?
I'm thinking it's a page with sound that for some reason isn't working properly. No reason why Maxthon should be doing anything like that otherwise.
7twenty replied at 2015-4-8 05:04 back.gif
Check to see if one of the tabs open is causing it. What happens when ...
i tried mute my sound in browser... still have static sound come out...
Oliver One replied at 2015-4-8 00:43 back.gif
Welcome,
I never noticed this kind of problem! Have you extensions installed?
how do i check my extension?
Oliver One replied at 2015-4-9 00:59 back.gif
Type about:extensions in the address bar.
these are my extensions
Hi,
Have your problem been solved? it sounds like there is something corrupted in your installation. Maybe you can upgrade to the new Maxthon 4.4.5.600 to see the problem get solved.
after I disable my TSL option in IE setting, seem static sound gone...
i supect is the error 36888 in my IE cause the noisy sound..
Followers 0
