Posted 13 Mar 2015 any time i try to open an advertisement on facebook i get back (redirected) to fb.com Share this post Link to post Share on other sites
Posted 13 Mar 2015 Try disable Adblock if you have it on (although you shouldn't have ads to click on if you did?) Does it happen with other browsers? Do you use any extensions? Disable them and try again. Share this post Link to post Share on other sites
Posted 14 Mar 2015 ad blocker is already disabled it is not a pop up ads it's facebook advertise and i like it and i like to explore it work fine on other browser no i i do not use extension previous version worked fine Share this post Link to post Share on other sites
Posted 14 Mar 2015 7twenty replied at 2015-3-13 13:57 Try disable Adblock if you have it on (although you shouldn't have ads to click on if you did?) Doe ... i use win 10 Share this post Link to post Share on other sites
Posted 14 Mar 2015 ioosis replied at 2015-3-13 19:39 i use win 10 i do not know why yr page report that wrong Share this post Link to post Share on other sites
Posted 14 Mar 2015 Because you have a very older User Agent. Disabled Customize UA string in advanced settings. 12581 Share this post Link to post Share on other sites
Posted 14 Mar 2015 Oliver One replied at 2015-3-13 23:29 Because you have a very older User Agent. Disabled Customize UA string in advanced settings. i did Share this post Link to post Share on other sites
Posted 14 Mar 2015 ioosis replied at 2015-3-13 23:32 i did still report win 8.1 i use 10 Share this post Link to post Share on other sites
Posted 14 Mar 2015 Currently Win 10 uses UA Win 8.1, it's normal. Now, can you retry Facebook? Share this post Link to post Share on other sites
Posted 14 Mar 2015 Oliver One replied at 2015-3-13 23:46 Currently Win 10 uses UA Win 8.1, it's normal. Now, can you retry Facebook? same problem oliver Share this post Link to post Share on other sites
Posted 14 Mar 2015 As I don't use Facebook, difficult to help you. Wait an user who uses! Share this post Link to post Share on other sites
Posted 19 Mar 2015 Hi ioosis, Sorry for this inconvenience brought to you. Here we tried to test it, but we did not replicate it. Please try to download the portable version with guest account then try again. Looking forward to hearing from you. Thanks for your support. Share this post Link to post Share on other sites
